      vserver iscsi interface enable
Enable the specified interfaces for iSCSI service
This command enables specified logical interfaces for iSCSI Vserver service. Once enabled, your system accepts new iSCSI connections and services iSCSI requests over the newly enabled logical interfaces.
- -vserver <Vserver Name>- Vserver
Specifies the Vserver.
- { -lif <lif-name>,…- Logical Interface
Specifies the logical interfaces on a Vserver that you want to enable.
- | -a, -all <true>- All }
When set to true, all logical interfaces are enabled. If you use this parameter without a value, it is set to true, and the command enables all logical interfaces.
cluster1::> vserver iscsi interface enable -vserver vs_1 -lif vs_1.iscsi
Enables the iscsi logical interface vs_1.iscsi on Vserver vs_1.
 PDFs
PDFs
