storage port show
Show storage port information
The storage port show command displays information about the storage ports in the cluster. If no parameters are specified, the default command displays the following information about the storage ports:
Node
Port
Type
Speed
State
Status
To display detailed profile information about a single storage port, use the -node and -port parameters.
[-fields <fieldname>,…] -
Displays the specified fields for all the storage ports, in column style output.
[-errors ] -
Displays the following error status information about the storage ports which have errors:
Error type
Error severity
Error description
[-instance ]} -
Displays expanded information about all the storage ports in the system. If a storage port is specified, then this parameter displays detailed information for that port only.
[-node {<nodename>|local}]- Node-
Displays detailed information about the storage ports on the specified node.
[-port <text>]- Port-
Selects the ports with the specified port name.
[-port-type {Unknown|SAS|FC}]- Port Type-
Selects the ports of the specified type.
[-port-speed {0|1|1.5|2|3|4|6|8|10|12|16|32}]- Port Speed-
Selects the ports with the specified speed.
[-state {enabled|disabled}]- Port State-
Selects the ports with the specified state.
[-status {unknown|online|online-degraded|offline|link-down}]- Port Status-
Selects the ports with the specified operational status.
[-description <text>]- Description-
Selects the ports with the specified description.
[-firmware-rev <text>]- Firmware Revision-
Selects the ports with the specified firmware revision.
[-serial-number <text>]- Serial Number-
Selects the ports with the specified serial number.
[-connection-mode {Unknown|Loop|Point-to-point}]- Connection Mode-
Selects the ports with the specified connection mode.
[-wwnn <FC WWN>]- World Wide Node Name-
Selects the ports with the specified World Wide Node Name.
[-wwpn <FC WWN>]- World Wide Port Name-
Selects the ports with the specified World Wide Port Name.
[-board-name <text>]- Board Name-
Selects the ports with the specified board name.
[-connector-capabilities <integer>,…]- Connector Capabilities-
Selects the ports with the specified list of connector capabilities.
[-wwn <FC WWN>]- Base World Wide Name-
Selects the ports with the specified World Wide Name.
[-mfg-part-number <text>]- MFG Part Number-
Selects the ports with the specified manufacturer part number.
[-nvdata-rev <text>]- NVDATA Revision-
Selects the ports with the specified NVDATA revision.
[-part-number <text>]- Part Number-
Selects the ports with the specified part number.
[-date-code <text>]- Date Code-
Selects the ports with the specified date code.
[-cable-length <text>]- Cable Length-
Selects the ports with the specified cable length.
[-cable-identifier <text>]- Cable Identifier-
Selects the ports with the specified cable identifier.
[-cable-end-id {end_0|end_1}]- Cable End Identifier-
Selects the ports with the specified cable end identifier.
[-connector-technology {active-copper|passive-copper|optical}]- Connector Technology-
Selects the ports with the specified connector technology.
[-phy-id <integer>,…]- Phy ID-
Selects the ports that have phys with the specified phy ID.
[-phy-state {enabled|disabled}]- Phy State-
Selects the ports that have phys with the specified state.
[-phy-status {unknown|online|offline|speed-negotiation-failed|sata-oob-failed}]- Phy Status-
Selects the ports that have phys with the specified status.
[-phy-speed {0|1|1.5|2|3|4|6|8|10|12|16|32}]- Phy Speed-
Selects the ports that have phys with the specified speed.
[-error-type {unknown|online|online-degraded|offline|link-down}]- Error Type-
Selects the ports with the specified error type.
[-error-severity {unknown|notice|warning|error|critical}]- Error Severity-
Selects the ports with the specified error severity.
[-error-text <text>]- Error Text-
Selects the ports with the specified error text.
[-corrective-action <text>]- Corrective Action-
Selects the ports with the specified corrective action.
[-connector-type {QSFP|QSFP+|Mini-SAS HD|SFP}]- Connector Type-
Selects the ports with the specified connector type.
[-connector-vendor <text>]- Connector Vendor-
Selects the ports with the specified connector vendor.
[-connector-part-number <text>]- Connector Part Number-
Selects the ports with the specified connector part number.
[-connector-serial-number <text>]- Connector Serial Number-
Selects the ports with the specified connector serial number.
The following example displays information about all storage ports in the cluster:
cluster1::> storage port show
Speed
Node Port Type (Gb/s) State Status
node1
0a SAS 0 disabled offline
0b SAS 6 enabled online
1a FC 0 disabled offline
1b FC 2 enabled online
node2
0a SAS 6 enabled online
0b SAS 6 enabled online-degraded
1a FC 2 enabled online
The following example displays detailed information about port 0a on node node1:
cluster1::> storage port show -node node1 -port 0b
Node: node1
Port: 0b
Description: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C)
Firmware Revision: 01.12.06.00
Base WWN: 50:0a:09:80:00:82:47:b4
Connector Type: qsfp
Connector Vendor: Molex Inc.
Connector Part Number: 112-00177+A0
Connector Technology: passive_copper
Connector Serial Number: 017920547
Cable Length: 2m
Cable End Identifier: end_1
Cable Identifier: 500a09800082847f-500a0980008247b4
Port Speed: 6 Gb/s
Port State: enabled
Port Status: online
Phy State: [0] enabled, online, 6 Gb/s
[1] enabled, online, 6 Gb/s
[2] enabled, online, 6 Gb/s
[3] enabled, online, 6 Gb/s
