      vserver cifs home-directory search-path remove
Remove a home directory search path
The vserver cifs home-directory search-path remove command removes a search path from a CIFS home directory configuration.
-vserver <vserver name>- Vserver-
This parameter specifies the CIFS-enabled Vserver containing the CIFS home directory configuration from which you want to remove the search path.
 -path <text>- Path-
This parameter specifies the search path you want to remove.
The following example removes the path /home1 from the CIFS home directory configuration on Vserver vs1.
cluster1::> vserver cifs home-directory search-path remove -vserver vs1 -path /home1
