The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs home-directory search-path remove
PDF of this doc site
Creating your file...
Your file is ready
Remove a home directory search path
The vserver cifs home-directory search-path remove
command removes a search path from a CIFS home directory configuration.
-vserver <vserver name>
- Vserver-
This parameter specifies the CIFS-enabled Vserver containing the CIFS home directory configuration from which you want to remove the search path.
-path <text>
- Path-
This parameter specifies the search path you want to remove.
The following example removes the path /home1 from the CIFS home directory configuration on Vserver vs1.
cluster1::> vserver cifs home-directory search-path remove -vserver vs1 -path /home1
