      vserver iscsi security prepare-to-downgrade
Prepares the system for downgrade
This command prepares the cluster for a downgrade to an earlier version of Data ONTAP. Before using this command verify that all security entries do not have any initiator address ranges defined. This may be done by running the command vserver iscsi security show address-ranges
cluster1::> vserver iscsi security prepare-to-downgrade
The above example will verify that the cluster is able to downgrade to a prior release of Data ONTAP.
 PDFs
PDFs
