vserver show
Display Vservers
The vserver show command displays the following information:
Vserver name
Vserver type (
data,admin,nodeorsystem- detailed view only) -
Vserver subtype (
default,dp-destination,sync-source, andsync-destination- detailed view only) -
Vserver universal unique identifier (detailed view only)
Root volume name
Aggregate on which the root volume is located
Associated NIS domain
Root volume security style (
unixfor UNIX mode bits,ntfsfor CIFS ACLs,mixedfor both (detailed view only) -
LDAP client
Language (detailed view only)
Snapshot policy (detailed view only)
Comment text (detailed view only)
Quota policy (detailed view only)
Aggregate list (detailed view only)
Maximum Volumes (detailed view only)
Qos-policy-group (detailed view only)
Config-lock (detailed view only)
Admin state (
running,stopped,starting,stopping,initializing, ordeleting) -
Operational state (
running, orstopped) -
Operational state stopped reason (
sync-destination-and-switchover-not-done, orcluster-reboot-done, oradmin-state-stopped) -
Allowed Protocols (
nfs,cifs,fcp,iscsi,nvme,ndmp- detailed view only) -
Disallowed Protocols (
IPspace to which the Vserver belongs (detailed view only)
Caching policy
[-fields <fieldname>,…] -
If you specify the
[-protocols ] -
If this optional parameter is specified, the command displays the allowed and disallowed set of protocols for the Vserver(s).
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
If this parameter is specified, the command displays detailed information about the specified Vserver.
[-type <vserver type>]- Vserver Type-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Vserver type. Types include
adminfor the cluster-wide management Vserver,systemfor cluster-level communications in an IPspace,datafor data serving Vserver, andnodefor node management Vserver. [-subtype <vserver subtype>]- Vserver Subtype-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Vserver subtype. Types include:
defaultfor default data Vserver
and -
dp-destinationfor Data Protection destination Vserver. -
sync-sourcefor MetroCluster source Vserver, -
sync-destinationfor MetroCluster destination Vserver.
[-uuid <UUID>]- Vserver UUID-
If this parameter is specified, the command displays information only about the Vserver that match the specified UUID.
[-rootvolume <volume name>]- Root Volume-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified root volume.
[-aggregate <aggregate name>]- Aggregate-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have their root volumes contained by the specified aggregate.
[-nisdomain <nis domain>]- NIS Domain-
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified NIS domain.
[-rootvolume-security-style <security style>]- Root Volume Security Style-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified root-volume security style.
[-ldap-client <text>]- LDAP Client-
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified LDAP client.
[-language <Language code>]- Default Volume Language Code-
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified language. To determine the available languages, enter "`vserver show
-language`?`` " at the clustershell command prompt and at the Vserver prompt. [-snapshot-policy <snapshot policy>]- Snapshot Policy-
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Snapshot policy.
[-comment <text>]- Comment-
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified comment.
[-quota-policy <text>]- Quota Policy-
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified quota policy.
[-aggr-list <aggregate name>,…]- List of Aggregates Assigned-
If this parameter is specified, the command displays information only about the Vserver or Vservers to which the specified aggregate(s) are assigned for use.
[-max-volumes <unsigned32_or_unlimited>]- Limit on Maximum Number of Volumes allowed-
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified maximum volume count is configured.
[-admin-state {running|stopped|starting|stopping}]- Vserver Admin State-
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified admin-state.
[-operational-state {running|stopped}]- Vserver Operational State-
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified operational-state. This field determines the state of the Vserver LIFs. New LIFs created on a Vserver, which is in running state, will be operationally up and the LIFs created on a Vserver, which is in stopped state, will be operationally down.
[-operational-state-stopped-reason {sync destination and switchover is not done|cluster reboot is done|admin state stopped| dp destination not started}]- Vserver Operational State Stopped Reason-
If this parameter is specified, the command displays information only about the Vserver or Vservers that are operationally stopped due to the specified reason. This field indicates the reason for the operational-state of the Vserver being stopped
[-allowed-protocols {nfs|cifs|fcp|iscsi|ndmp|nvme}]- Allowed Protocols-
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified protocols are allowed to run.
[-disallowed-protocols {nfs|cifs|fcp|iscsi|ndmp|nvme}]- Disallowed Protocols-
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified protocols are disallowed to run.
[-is-repository {true|false}]- Is Vserver with Infinite Volume-
If this parameter is no longer supported.
[-qos-policy-group <text>]- QoS Policy Group-
Display the Vservers that match the specified qos-policy-group.
A policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated. If you do not assign a policy group to a Vserver, the system will not monitor and control the traffic to it.
[-caching-policy <text>]- Caching Policy Name-
Display the Vservers that match the specified caching-policy.
A caching policy defines the caching behavior of this Vserver at the Flash Cache level. If a caching policy is not assigned to this Vserver, the system uses the default cluster-wide policy. The available caching policies are:
none - Does not cache any user data or metadata blocks.
auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
Default caching-policy is auto.
[-config-lock {true|false}]- Config Lock-
This parameter specifies if the Vserver is locked or unlocked for modification. If the config-lock is set to true, then modifying the Vserver's configuration is not allowed.
[-ipspace <IPspace>]- IPspace Name-
If this parameter is specified, the command displays information only about the Vservers that are assigned to the specified IPspace.
[-foreground {true|false}]- Foreground Process-
This optionally specifies whether the Vserver show operation can be executed in the background. If nothing is specified, by default the Vserver show operation is executed in the foreground.
[-is-space-reporting-logical {true|false}]- Logical Space Reporting-
This optionally specifies whether to report space logically on residing volumes. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also as reported as used. This parameter is not supported on FlexGroups.
[-is-space-enforcement-logical {true|false}]- Logical Space Enforcement-
This optionally specifies whether to perform logical space accounting on residing volumes. When space is enforced logically, ONTAP enforces volume settings such that all the physical space saved by the storage efficiency features will be calculated as used. This parameter is not supported on FlexGroups.
The following example displays information about all Vservers.
cluster1::> vserver show
non mcc setup:
Admin Operational Root
Vserver Type Subtype state state Volume Aggregate
cluster admin - - - - -
node1 node - - - - -
vs0 data default running running root_vs1 aggr0
vs1 data dp-destination stopped stopped - -
4 entries were displayed.
mcc setup:
vs2 data sync-source running running rv data_aggr
vs3-mc data sync-destination running stopped - -
