metrocluster show
Display MetroCluster configuration information
The metrocluster show command displays configuration information for the pair of clusters configured in MetroCluster.
This command displays the following details about the local cluster and the DR partner cluster:
  • Configuration State: This field specifies the configuration state of the cluster.
  • Mode: This field specifies the operational mode of the cluster.
  • AUSO Failure Domain: This field specifies the AUSO failure domain of the cluster.
Parameters</
