ONTAP commands
volume encryption conversion resume
Resume a paused volume encryption conversion operation
The volume encryption conversion resume command resumes the paused encryption conversion operation on a volume.
-vserver <vserver name> - Vserver Name
This parameter specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This parameter specifies the name of the volume being encrypted.
