system node virtual-machine disk-object-store show
Display the list of object store configurations
The system node virtual-machine disk-object-store show command displays the list of object store containers that contain each node’s disks.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - ONTAP Node Name
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-object-store-name <object store name>] - ONTAP Name for this Object Store Config
Selects object store configurations with the specified name.
[-server <text>] - Fully Qualified Domain Name of the Object Store Server
Selects containers on the specified server.
[-port <integer>] - Port Number of the Object Store
Selects containers attached on the specified port.
[-container-name <text>] - Container Name
Selects containers with the specified name.
[-azure-account <text>] - Azure Storage Account
Selects containers in the specified Azure storage account.
[-alive {true|false}] - Is Server Alive
Selects containers based on their aliveness state, as seen from the ONTAP node.
The following example displays the list of containers for each node in the cluster.
cluster1::*> system node virtual-machine disk-object-store show
                  Object Store
     Node         Name         Azure Storage Account   Container Name   Alive
     node1
                  objstore1    storageaccount1         container1        true
     node2
     2 entries were displayed.
