system service-processor network show
Display the network configuration
The system service-processor network show command displays the network configuration of the Service Processor of each node in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
In case a node is offline or its Service Processor management daemon is down, the command displays the last known IP address of its Service Processor. Only the IP address is displayed in such cases.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects network configuration information for the Service Processor of the specified node.
[-address-family {IPv4|IPv6}]- Address Family-
Selects network configuration information for the Service Processors that have the specified IP address family.
[-enable {true|false}]- Interface Enabled-
Selects network configuration information for the Service Processors whose network interface for the given
address-familyis enabled or disabled as specified. [-type {SP|NONE|BMC}]- Type of Device-
Selects network configuration information for the Service Processors of the specified type.
[-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}]- Status-
Selects network configuration information for the Service Processors whose status matches the specified value.
[-link-status {up|down|disabled|unknown}]- Link Status-
Selects network configuration information for the Service Processors whose link status matches the specified value.
[-dhcp {v4|none}]- DHCP Status-
Selects network configuration information for the Service Processors whose DHCP status matches the specified value.
[-ip-address <IP Address>]- IP Address-
Selects network configuration information for the Service Processors that use the specified IP address.
[-mac <MAC Address>]- MAC Address-
Selects network configuration information for the Service Processors that use the specified MAC address.
[-netmask <IP Address>]- Netmask-
This parameter displays information only for the Service Processors that use the specified netmask.
[-prefix-length <integer>]- Prefix Length of Subnet Mask-
Selects network configuration information for the Service Processors whose prefix length of subnet mask matches the specified value.
[-router-ip <IP Address>]- Router Assigned IP Address-
Selects network configuration information for the Service Processors whose router-assigned IP address matches the specified value.
[-link-local-ip <IP Address>]- Link Local IP Address-
Selects network configuration information for the Service Processors whose link local IP address matches the specified value.
[-gateway <IP Address>]- Gateway IP Address-
Selects network configuration information for the Service Processors whose gateway IP address matches the specified value.
[-time-last-updated <text>]- Time Last Updated-
Selects network information for the Service Processors that have the specified time stamp showing when configuration was last updated.
[-subnet-name <text>]- Subnet Name-
Selects network information for the Service Processors that use the specified subnet-name for SP automatic configuration.
[-is-ipv6-ra-enabled {true|false}]- Enable IPv6 Router Assigned Address-
Selects network information for the Service Processors that have the specified status for IPv6 router-assigned address.
[-setup-status {not-setup|succeeded|in-progress|failed}]- SP Network Setup Status-
Selects network information for the Service Processors that have the specified status for network interface setup.
[-setup-failure-reason {success|subnet-out-of-address|invalid-subnet|other-error}]- SP Network Setup Failure Reason-
Selects network information for the Service Processors that have the specified reason for network interface setup failure.
The following example displays basic network configuration information for the Service Processors of all the nodes.
cluster1::> system service-processor network show
Address
Node Status Type Link State IP Address
node1 online IPv4 up 192.168.1.201
DHCP: v4
MAC Address: ab:cd:ef:fe:ed:01
Network Gateway: 192.168.1.1
Network Mask (IPv4 only): 255.255.255.0
Prefix Length (IPv6 only): -
IPv6 RA Enabled: -
Subnet Name: -
SP Network Setup Status: succeeded
node1 online IPv6 disabled -
DHCP: none
Network Gateway: -
Network Mask (IPv4 only): -
IPv6 RA Enabled: -
Subnet Name: -
SP Network Setup Status: not-setup
node2 online IPv4 up 192.168.1.202
DHCP: v4
MAC Address: ab:cd:ef:fe:ed:02
IPv6 RA Enabled: -
Subnet Name: -
node2 online IPv6 disabled -
DHCP: none
Network Gateway: -
IPv6 RA Enabled: -
Subnet Name: -
4 entries were displayed.
cluster1::>
The following example displays all available network configuration information for the Service Processors of all the nodes.
cluster1::> system service-processor network show -instance
Node: node1
Address Family: IPv4
Interface Enabled: true
Type of Device: SP
Status: online
Link Status: up
DHCP Status: v4
IP Address: 192.168.1.201
Netmask: 255.255.255.0
Prefix Length of Subnet Mask: -
Router Assigned IP Address: -
Link Local IP Address: -
Gateway IP Address: 192.168.1.1
Time Last Updated: Fri Jun 13 17:03:59 GMT 2014
Subnet Name: -
Enable IPv6 Router Assigned Address: -
SP Network Setup Failure Reason: -
Node: node1
Address Family: IPv6
Interface Enabled: false
Type of Device: SP
Status: online
Link Status: disabled
DHCP Status: none
IP Address: -
Netmask: -
Gateway IP Address: -
Subnet Name: -
Node: node2
Type of Device: SP
Status: online
Link Status: up
DHCP Status: v4
IP Address: 192.168.1.202
Subnet Name: -
Node: node2
Type of Device: SP
Status: online
DHCP Status: none
IP Address: -
Netmask: -
Subnet Name: -
cluster1::>
