storage aggregate show-status
Display aggregate configuration
The storage aggregate show-status command displays the RAID layout and disk configuration of aggregates. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays information about all aggregates in the cluster.
This command does not use pagination. You can reduce the output by filtering with the parameters below. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
This parameter currently has no effect.
[-aggregate <text>]- Aggregate Name-
Selects the aggregates that match this parameter value.
[-node <nodename>]- Node-
[-aggregate-uuid <UUID>]- Aggregate UUID-
Display the RAID layout of a Flash Pool aggregate.
cluster1::> storage aggregate show-status -aggregate nodeB_flashpool_1
Owner Node: node-b
Aggregate: nodeB_flashpool_1 (online, raid_dp, hybrid) (block checksums)
Plex: /nodeB_flashpool_1/plex0 (online, normal, active, pool0)
RAID Group /nodeB_flashpool_1/plex0/rg0 (normal, block checksums)
Usable Physical
Position Disk Pool Type RPM Size Size Status
dparity 1.1.7 0 BSAS 7200 827.7GB 828.0GB (normal)
parity 1.1.8 0 BSAS 7200 827.7GB 828.0GB (normal)
data 1.1.10 0 BSAS 7200 827.7GB 828.0GB (normal)
data 1.1.11 0 BSAS 7200 827.7GB 828.0GB (normal)
data 1.1.12 0 BSAS 7200 827.7GB 828.0GB (normal)
RAID Group /nodeB_flashpool_1/plex0/rg1 (normal, block checksums) (Storage Pool: SP2)
Usable Physical
shared 1.0.22 0 SSD - 186.2GB 745.2GB (normal)
shared 1.0.20 0 SSD - 186.2GB 745.2GB (normal)
shared 1.0.18 0 SSD - 186.2GB 745.2GB (normal)
shared 1.0.16 0 SSD - 186.2GB 745.2GB (normal)
