security login role show
Show access control roles
The security login role show command displays the following information about access-control roles:
Role name
Command or command directory to which the role has access
Access level (none, read-only, or all)
Query (detailed view only)
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the roles that match this parameter value.
 [-role <text>]- Role Name-
Selects the roles that match this parameter value. If this parameter and the
-cmddirnameparameter are both used, the command displays detailed information about the specified access-control role. [-cmddirname <text>]- Command / Directory-
-roleparameter are both used, the command displays detailed information about the specified access-control role. [-access <Access>]- Access Level-
 [-query <query>]- Query-
The example below displays information about all access-control roles:
cluster1::> security login role show Vserver RoleName Command/Directory Query AccessLevel ---------- ------------- -------------------------------- ----- ----------- vs vsadmin DEFAULT none vs vsadmin dashboard health vserver readonly vs vsadmin job readonly vs vsadmin job schedule none vs vsadmin lun all vs vsadmin network connections readonly cluster1 admin DEFAULT all cluster1 readonly DEFAULT readonly cluster1 readonly volume none
