ONTAP commands
security login role show
Show access control roles
The security login role show command displays the following information about access-control roles:
  • Role name
  • Command or command directory to which the role has access
  • Access level (none, read-only, or all)
  • Query (detailed view only)
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the roles that match this parameter value.
[-role <text>] - Role Name
Selects the roles that match this parameter value. If this parameter and the -cmddirname parameter are both used, the command displays detailed information about the specified access-control role.
[-cmddirname <text>] - Command / Directory
Selects the roles that match this parameter value. If this parameter and the -role parameter are both used, the command displays detailed information about the specified access-control role.
[-access {none|readonly|read_create|read_modify|read_create_modify|all}] - Access Level
[-query <query>] - Query
The example below displays information about all access-control roles:
cluster1::> security login role show
Vserver    RoleName      Command/Directory                Query AccessLevel
vs         vsadmin       DEFAULT                                none
vs         vsadmin       dashboard health vserver               readonly
vs         vsadmin       job                                    readonly
vs         vsadmin       job schedule                           none
vs         vsadmin       lun                                    all
vs         vsadmin       network connections                    readonly
cluster1   admin         DEFAULT                                all
cluster1   readonly      DEFAULT                                readonly
cluster1   readonly      volume                                 none
