storage tape config-file show
Display the list of tape drive configuration files on the given node
The storage tape config-file show command lists the tape drive configuration files loaded onto each node in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information about tape drive configuration files for the specified node.
 [-config-file <text>]- Tape Config File-
Selects information about the tape drive configuration file specified.
The following example lists the tape drive config files loaded onto each node in the cluster:
cluster1::> storage tape config-file show Node: node1 Tape Config Files ---------------------------------------- CERTANCE_LTO2_ULTRIUM.TCF CERTANCE_LTO3_ULTRIUM.TCF HP_LT09.TCF HP_LTO2.TCF HP_LTO3_ULTRIUM.TCF HP_LTO4_ULTRIUM.TCF HP_LTO5_ULTRIUM.TCF HP_LTO6_ULTRIUM.TCF IBM_3592.TCF IBM_3592E05.TCF IBM_5038_sdfkjl.TCF IBM_LTO2_ULT3580.TCF IBM_LTO2_ULTRIUM.TCF
