volume quota off
Turn off quotas for volumes
This command creates a job to deactivate quotas for the specified volume. You can monitor the progress of the job by using the job show and job watch-progress commands.
-vserver <vserver name> - Vserver Name
This specifies the name of the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which you are deactivating quotas.
[-foreground <true>] - Foreground Process
This optionally specifies whether the job created for deactivating quotas runs as a foreground process. The default setting is false (that is, the operation runs in the background). When set to true , the command will not return until the job completes.
The following example deactivates quotas on the volume named vol1 , which exists on Vserver vs0 .
cluster1::> volume quota off -vserver vs0 -volume vol1
[Job 23] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to deactivate quotas on the volume named vol1 which exists on Vserver vs0 .
cluster1::> vserver context vs0
vs0::> quota off vol1
[Job 25] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
