network bgp peer-group rename
Rename a BGP peer group
The network bgp peer-group rename
command is used to assign a new name to a BGP peer group.
-ipspace <IPspace>
- IPspace Name-
This parameter specifies the IPspace of the peer group being renamed.
-peer-group <text>
- Peer Group Name-
The name of the peer group to be updated.
-new-name <text>
- New Name-
The new name for the peer group.
cluster1::> network bgp peer-group rename -peer-group old_name -new-name new_name
