storage tape alias show
Displays aliases of all tape drives and media changers
This command displays aliases of all tape drives and media changers attached to every node in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields.
The following example shows the aliases of all tape drives and media changers attached to every node in the cluster:
cluster1::> storage tape alias show Node: node1 Alias Mapping -------------------------------------- ---------------------------------------- mc0 SN[00FRU7800000_LL0]L1 mc1 SN[00FRU7800000_LL1]L1 mc2 SN[aa6a64c69360a0980248c8] mc3 SN[c940abe8b0c3a0980248c8] mc4 SN[fba082e6b335a0980248c8]L5 st0 SN[HU19487T7N] st1 SN[1068000230] st10 SN[fba0c508b335a0980248c8]L7 Node: node2 Alias Mapping -------------------------------------- ---------------------------------------- mc1 SN[c940982fc48c8] st3 SN[ST456HT8N]L3 st2 SN[HG68000230]L2 st11 SN[aba673980248c8]L7
