network fcp adapter show
Display FCP adapters
Displays FCP target adapter information. You can also use this information to determine if adapters are active and online.
The adapter argument is in the form Xy or Xy_z where X and z are integers and y is a letter. An example is 4a or 4a_1.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified, the command displays information only about the FCP target adapters that are present on the specified node.
 [-adapter <text>]- Adapter-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified name.
 [-description <text>]- Description-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified description.
 [-physical-protocol {fibre-channel|ethernet}]- Physical Protocol-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified physical protocol. Possible values are
fibre-channelandethernet. [-max-speed {1|2|4|8|10|16|32|auto}]- Maximum Speed-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified maxium speed.
 [-status-admin {down|up}]- Administrative Status-
If this parameter is specified, the command displays information only about the FCP target adapters that match the administrative state. Possible values are
upanddown. [-status-oper <text>]- Operational Status-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified operational status.
 [-status-extended <text>]- Extended Status-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified extended status.
 [-portaddr <Hex Integer>]- Host Port Address-
If this parameter is specified, the command displays information only about the FCP target adapters connected with the specified fabric port address.
 [-firmware-rev <text>]- Firmware Revision-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified firmware revision.
 [-data-link-rate <integer>]- Data Link Rate (Gbit)-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified data link rate.
 [-fabric-established {true|false}]- Fabric Established-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified fabric login establishment state.
 [-fabric-name <text>]- Fabric Name-
If this parameter is specified, the command displays information only about the FCP target adapters that are logged in to the fabric with the specified WWN.
 [-conn-established {loop|ptp}]- Connection Established-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified connection type. Possible values are
loopandptp. [-is-conn-established {true|false}]- Is Connection Established-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified connection established state.
 [-media-type {loop|ptp|auto}]- Mediatype-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified configured media type. Possible values are
loop,ptp, andauto. [-speed {1|2|4|8|10|16|32|auto}]- Configured Speed-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified configured speed. If the adapter is set to auto-negotiate, then the value will be
auto. [-data-protocols-supported {fcp|fc-nvme}]- Data Protocols Supported-
If this parameter is specified, the command displays information only about the FCP target adapters that may host LIFs with the specified data protocol. Possible values are
fcpandfc-nvme. [-fc-wwnn <text>]- Adapter WWNN-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified world wide node name.
 [-fc-wwpn <text>]- Adapter WWPN-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified world wide port name.
 [-switch-port <text>]- Switch Port-
If this parameter is specified, the command displays information only about the FCP target adapters that are connected to the specified switch port.
 [-sfp-formfactor <text>]- Form Factor Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP form factor.
 [-sfp-vendor-name <text>]- Vendor Name Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP vendor name.
 [-sfp-part-number <text>]- Part Number Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP part number.
 [-sfp-rev <text>]- Revision Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP revision number.
 [-sfp-serial-number <text>]- Serial Number Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP serial number.
 [-sfp-fc-speed-capabilities <text>]- FC Capabilities Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP speed capabilities.
 [-sfp-vendor-oui <text>]- Vendor OUI Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP vendor OUI.
 [-sfp-wavelength <integer>]- Wavelength In Nanometers-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP wavelength.
 [-sfp-date-code <text>]- Date Code Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP date code.
 [-is-sfp-optical-transceiver-valid {true|false}]- Validity Of Transceiver-
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the SFP is installed and valid.
 [-sfp-connector <text>]- Connector Used-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP connector type.
 [-sfp-encoding <text>]- Encoding Used-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP physical encoding.
 [-is-sfp-diagnostics-internally-calibrated {true|false}]- Is Internally Calibrated-
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the SFP diagnostics are internally calibrated or not.
 [-sfp-rx-power <text>]- Received Optical Power-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified observed SFP receive power.
 [-is-sfp-rx-power-in-range {true|false}]- Is Received Power In Range-
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP receive power is within the valid range for the SFP.
 [-sfp-tx-power <text>]- SFP Transmitted Optical Power-
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP transmit power.
 [-is-sfp-tx-power-in-range {true|false}]- Is Xmit Power In Range-
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP transmit power is within the valid range for the SFP.
cluster1::> fcp adapter show
                     Connection  Host
Node         Adapter Established Port Address
sti6280-021   0a      ptp         30012c
The example above displays information regarding FCP adapters within cluster1.
cluster1::> fcp adapter show -instance -node sti6280-021 -adapter 0a
Node: sti6280-021
                       Adapter: 0a
                   Description: Fibre Channel Target Adapter 0a (QLogic 2532 (2562), rev. 2, 8G)
             Physical Protocol: fibre-channel
                 Maximum Speed: 8
         Administrative Status: up
            Operational Status: online
               Extended Status: ADAPTER UP
             Host Port Address: 30012c
             Firmware Revision: 5.8.0
         Data Link Rate (Gbit): 4
            Fabric Established: true
                   Fabric Name: 20:14:54:7f:ee:54:b9:01
        Connection Established: ptp
     Is Connection Established: true
                     Mediatype: ptp
              Configured Speed: auto
                  Adapter WWNN: 50:0a:09:80:8f:7f:8b:1c
                  Adapter WWPN: 50:0a:09:81:8f:7f:8b:1c
                   Switch Port: RTP-AG01-410B51:1/41
    Form Factor Of Transceiver: SFP
    Vendor Name Of Transceiver: OPNEXT,INC
    Part Number Of Transceiver: TRS2000EN-SC01
       Revision Of Transceiver: 0000
  Serial Number Of Transceiver: T10H64793
FC Capabilities Of Transceiver: 10 (Gbit/sec)
     Vendor OUI Of Transceiver: 0:11:64
      Wavelength In Nanometers: 850
      Date Code Of Transceiver: 10:08:17
       Validity Of Transceiver: true
                Connector Used: LC
                 Encoding Used: 64B66B
      Is Internally Calibrated: true
        Received Optical Power: 441.3 (uWatts)
    Is Received Power In Range: true
 SFP Transmitted Optical Power: 600.4 (uWatts)
        Is Xmit Power In Range: true
The example above displays detailed information regarding FCP adapter 0a in sti6280-021 within cluster1.
