network fcp adapter show
Display FCP adapters
Displays FCP target adapter information. You can also use this information to determine if adapters are active and online.
The adapter argument is in the form Xy or Xy_z where X and z are integers and y is a letter. An example is 4a or 4a_1.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
If this parameter is specified, the command displays information only about the FCP target adapters that are present on the specified node.
- [-adapter <text>]- Adapter
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified name.
- [-description <text>]- Description
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified description.
- [-physical-protocol {fibre-channel|ethernet}]- Physical Protocol
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified physical protocol. Possible values are fibre-channelandethernet.
- [-max-speed {1|2|4|8|10|16|32|64|auto}]- Maximum Speed
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified maximum speed.
- [-status-admin {down|up}]- Administrative Status
If this parameter is specified, the command displays information only about the FCP target adapters that match the administrative state. Possible values are upanddown.
- [-status-oper <text>]- Operational Status
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified operational status.
- [-status-extended <text>]- Extended Status
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified extended status.
- [-portaddr <Hex Integer>]- Host Port Address
If this parameter is specified, the command displays information only about the FCP target adapters connected with the specified fabric port address.
- [-firmware-rev <text>]- Firmware Revision
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified firmware revision.
- [-data-link-rate <integer>]- Data Link Rate (Gbit)
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified data link rate.
- [-fabric-established {true|false}]- Fabric Established
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified fabric login establishment state.
- [-fabric-name <text>]- Fabric Name
If this parameter is specified, the command displays information only about the FCP target adapters that are logged in to the fabric with the specified WWN.
- [-conn-established {loop|ptp}]- Connection Established
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified connection type. Possible values are loopandptp.
- [-is-conn-established {true|false}]- Is Connection Established
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified connection established state.
- [-media-type {loop|ptp|auto}]- Mediatype
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified configured media type. Possible values are loop,ptp, andauto.
- [-speed {1|2|4|8|10|16|32|64|auto}]- Configured Speed
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified configured speed. If the adapter is set to auto-negotiate, then the value will be auto.
- [-data-protocols-supported {fcp|fc-nvme}]- Data Protocols Supported
If this parameter is specified, the command displays information only about the FCP target adapters that may host LIFs with the specified data protocol. Possible values are fcpandfc-nvme.
- [-domain-id <integer>]- Domain ID
If this parameter is specified, the command displays information only about the FCP target adapters with a domain identifier that matches the specified domain identifier.
- [-fc-wwnn <text>]- Adapter WWNN
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified world wide node name.
- [-fc-wwpn <text>]- Adapter WWPN
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified world wide port name.
- [-switch-port <text>]- Switch Port
If this parameter is specified, the command displays information only about the FCP target adapters that are connected to the specified switch port.
- [-sfp-formfactor <text>]- Form Factor Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP form factor.
- [-sfp-vendor-name <text>]- Vendor Name Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP vendor name.
- [-sfp-part-number <text>]- Part Number Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP part number.
- [-sfp-rev <text>]- Revision Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP revision number.
- [-sfp-serial-number <text>]- Serial Number Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP serial number.
- [-sfp-fc-speed-capabilities <text>]- FC Capabilities Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP speed capabilities.
- [-sfp-vendor-oui <text>]- Vendor OUI Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP vendor OUI.
- [-sfp-wavelength <integer>]- Wavelength In Nanometers
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP wavelength.
- [-sfp-date-code <text>]- Date Code Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP date code.
- [-is-sfp-optical-transceiver-valid {true|false}]- Validity Of Transceiver
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the SFP is installed and valid.
- [-sfp-connector <text>]- Connector Used
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP connector type.
- [-sfp-encoding <text>]- Encoding Used
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP physical encoding.
- [-is-sfp-diagnostics-internally-calibrated {true|false}]- Is Internally Calibrated
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the SFP diagnostics are internally calibrated or not.
- [-sfp-diagnostic-monitoring-type <Hex Integer>]- Diagnostic Monitoring Type
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP diagnostic monitoring type.
- [-sfp-ddm-capabilities <text>]- Status Monitoring Available
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the specified SFP digital diagnostics monitoring are supported or not.
- [-sfp-sff8472-compliance <Hex Integer>]- SFF-8472 Compliance
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP SFF8472 compliance.
- [-sfp-rx-power <text>]- Received Optical Power
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified observed SFP receive power.
- [-is-sfp-rx-power-in-range {true|false}]- Is Received Power In Range
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP receive power is within the valid range for the SFP.
- [-sfp-tx-power <text>]- SFP Transmitted Optical Power
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP transmit power.
- [-is-sfp-tx-power-in-range {true|false}]- Is Xmit Power In Range
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP transmit power is within the valid range for the SFP.
- [-sfp-ddm-status-control <Hex Integer>]- DDM Status
If this parameter is specified, the command displays information only about the FCP target adapters that match the specified SFP DDM status and control.
- [-is-sfp-tx-in-disable {true|false}]- Is Xmit Disabled
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP transmitter is in disabled state.
- [-is-sfp-tx-in-fault {true|false}]- Is Xmit In Fault
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP transmitter is in faulted state.
- [-is-sfp-rx-in-los {true|false}]- Is Receiver In LOS
If this parameter is specified, the command displays information only about the FCP target adapters that match whether the observed SFP receiver is in loss of signal state.
cluster1::> fcp adapter show
                     Connection  Host
Node         Adapter Established Port Address
sti6280-021   0a      ptp         30012c
The example above displays information regarding FCP adapters within cluster1.
cluster1::> fcp adapter show -instance -node sti6280-021 -adapter 0a
Node: sti6280-021
                       Adapter: 0a
                   Description: Fibre Channel Target Adapter 0a (QLogic 2532 (2562), rev. 2, 8G)
             Physical Protocol: fibre-channel
                 Maximum Speed: 8
         Administrative Status: up
            Operational Status: online
               Extended Status: ADAPTER UP
             Host Port Address: 30012c
             Firmware Revision: 5.8.0
         Data Link Rate (Gbit): 4
            Fabric Established: true
                   Fabric Name: 20:14:54:7f:ee:54:b9:01
        Connection Established: ptp
     Is Connection Established: true
                     Mediatype: ptp
              Configured Speed: auto
                  Adapter WWNN: 50:0a:09:80:8f:7f:8b:1c
                  Adapter WWPN: 50:0a:09:81:8f:7f:8b:1c
                   Switch Port: RTP-AG01-410B51:1/41
    Form Factor Of Transceiver: SFP
    Vendor Name Of Transceiver: OPNEXT,INC
    Part Number Of Transceiver: TRS2000EN-SC01
       Revision Of Transceiver: 0000
  Serial Number Of Transceiver: T10H64793
FC Capabilities Of Transceiver: 10 (Gbit/sec)
     Vendor OUI Of Transceiver: 0:11:64
      Wavelength In Nanometers: 850
      Date Code Of Transceiver: 10:08:17
       Validity Of Transceiver: true
                Connector Used: LC
                 Encoding Used: 64B66B
      Is Internally Calibrated: true
    Diagnostic Monitoring Type: 68
   Status Monitoring Available: fa {Rx_Loss_of_Sig, Tx_Fault, Tx_Disable}
           SFF-8472 Compliance: 5
        Received Optical Power: 441.3 (uWatts)
    Is Received Power In Range: true
 SFP Transmitted Optical Power: 600.4 (uWatts)
        Is Xmit Power In Range: true
                    DDM Status: 30
              Is Xmit Disabled: false
              Is Xmit In Fault: false
            Is Receiver In LOS: false
The example above displays detailed information regarding FCP adapter 0a in sti6280-021 within cluster1.
 PDFs
PDFs
