ONTAP commands
network tcpdump trace show
Show list of tcpdump trace files
The network tcpdump trace show command shows the list of tcpdump trace files. The trace files could be located in /mroot/etc/log/packet_traces/.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
Use this parameter to show the list of traces files of a matching node.
[-trace-file <text>] - Trace File
Use this parameter optionally to show the list of trace files with a matching trace-file name.
The following example shows the list of trace files on nodes "node1" and "node2":
cluster1::> network tcpdump trace show
Node            Trace File
node1
                e0a_20170314_115624.trc0
node2
                e0c_20170314_115624.trc0
