      system node hardware nvram-encryption modify
Configure NVRAM device encryption
The system node hardware nvram-encryption modify command configures the encryption feature for the NVRAM or NVMEM data that is destaged to non-volatile flash storage.
|  | This feature might be restricted in some countries due to local regulations concerning encrypted data. |
- -node {<nodename>|local}- Node
Specifies the node containing the NVRAM or NVMEM subsystem.
- [-is-enabled {true|false}]- Is Encryption Enabled
Specifies whether the NVRAM or NVMEM encryption is disabled or enabled.
The following commands enable or disable the NVRAM encryption:
cluster1::> system node hardware nvram-encryption modify  -node node1 -is-enabled false
      cluster1::> system node hardware nvram-encryption modify  -node node1 -is-enabled true
 PDFs
PDFs
