ONTAP commands
volume clone sharing-by-split undo stop
Stop an ongoing undo-sharing operation
The volume clone sharing-by-split undo stop command stops the process of reverting the shared physical blocks from the split volume. If you restart the undo-sharing operation, scan begins from the beginning because no information about previously achieved progress is saved, but previously unshared blocks are not processed again. This command is only supported for flexible volumes.
-vserver <Vserver Name> - Vserver Name (privilege: advanced)
This parameter specifies the vserver that the volume exists on.
-volume <volume name> - Volume Name (privilege: advanced)
This parameter specifies the volume whose unsharing of blocks will be stopped.
The following example stops an ongoing undo-sharing scan for volume vol_clone1 on vserver vs1 :
cluster1::> volume clone sharing-by-split undo stop -vserver vs1 -volume vol_clone1
