system node virtual-machine instance show-system-disks
(DEPRECATED) Display information about Data ONTAP-v system disks
This command is deprecated and may be removed in a future release of Data ONTAP. |
The system node virtual-machine instance show-system-disks command displays the system disks information of the Data ONTAP node running on the virtual machine. There are three types of Data ONTAP-v system disks - boot, core and log. The details contain the physical properties of the disk and its backing information (e.g. backing store name, iSCSI Lun UUID, etc). To filter command output, specify any number of optional fields listed below.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
The name of the Data ONTAP node running in a virtual machine for which information is to be displayed. If this optional parameter is not specified, the command displays information about all nodes in the cluster.
[-vmdisk-type <text>]- Type of the System Disk-
The type of the system disk, for example "Boot", "Core" or "Log". This optional parameter selects the information about the system disk with the specified type.
[-vmdisk-name <text>]- Data ONTAP Supplied Name of the System Disk-
The Data ONTAP-supplied name of the system disk. This optional parameter selects the information about the system disk with the specified name.
[-vmdisk-serial-number <text>]- Data ONTAP Supplied Serial Number of the System Disk-
The Data ONTAP-supplied serial number of the system disk. This optional parameter selects the information about system disk with the specified serial number.
[-vmdisk-capacity {<integer>[KB|MB|GB|TB|PB]}]- Size of the System Disk-
The size of the system disk. This optional parameter selects the information about system disks with the specified size.
[-vmdisk-area-name <text>]- Name of the System Disk Backing Store-
The name of the disk backing store. A backing store represents a storage location for virtual machine files. It can be a VMFS volume, a directory on network-attached storage, or a local file system path. This optional parameter selects the information about the system disks that reside on the specified backing store.
[-vmdisk-file-name <text>]- File Name of the System Disk Used By the Hypervisor-
The file name of the virtual disk used by the hypervisor. Each Data ONTAP disk is mapped to a unique VM disk file. This optional parameter selects the information about the system disk mapped to the specified file name.
[-vmdisk-backing-store-type <text>]- Type of the System Disk Backing Store-
The type of the disk backing store. It can be a VMFS volume, a directory on network-attached storage, or a local file system path. This optional parameter selects the information about the system disks that are backed by the specified type.
[-vmdisk-backing-store-capacity {<integer>[KB|MB|GB|TB|PB]}]- Size of the System Disk Backing Store-
The size of the disk backing store. This optional parameter selects the information about the system disks that are backed by stores with the specified capacity.
[-vmdisk-backing-store-nas-path <text>]- Full Path to the Backing Store for NAS-
The full path to the backing store for network-attached storage. This optional parameter selects the information about the system disks with the specified NAS path.
[-vmdisk-backing-adapter-pci <text>]- Backing Adapter PCI Device ID-
The backing adapter PCI device ID for the virtual disk. This optional parameter selects the information about the system disks that have the specified ID as their backing adapter PCI ID.
[-vmdisk-backing-adapter-device <text>]- Name of the Backing Adapter Device-
The name of the backing adapter device. This optional parameter selects the information about the system disks that have the specified name as their backing adapter device name.
[-vmdisk-backing-adapter-model <text>]- Type of the Backing Adapter Model-
The type of the backing adapter model. This optional parameter selects the information about the system disks that have the specified type as their backing adapter model type.
[-vmdisk-backing-adapter-driver <text>]- Backing Adapter Driver Name of the Initiator-
The backing adapter driver name of the initiator. This optional parameter selects the information about the system disks that have the specified name as their initiator's backing adapter driver name.
[-vmdisk-backing-target-iscsi-name <text>]- iSCSI Name of the System Disk Backing Target-
The iSCSI name of the disk backing target. This field is valid only for iSCSI connections. This optional parameter selects the information about the system disks that have the specified name as their backing device iSCSI target name.
[-vmdisk-backing-target-iscsi-address <text>]- iSCSI IP Address of the System Disk Backing Target-
The iSCSI IP address of the disk backing target. This field is valid only for iSCSI connections. This optional parameter selects the information about the system disks that have the specified IP as their backing device iSCSI target IP address.
[-vmdisk-backing-device-address <text>]- SCSI Device Name (target-id:lun-id) for the Backing Disk-
The SCSI device name for the backing disk. It takes the form target-id:lun-id, for example "2:1". This optional parameter selects the information about the system disks that have the specified backing device address.
[-vmdisk-backing-device-uuid <text>]- Hypervisor-Assigned Unique ID of the Backing Device-
The hypervisor-assigned unique ID of the backing device (disk or LUN). This optional parameter selects the information about system disks that are backed by a device with the specified UUID.
[-vmdisk-backing-device-partition <integer>]- Backing Disk Partition Number for the VM Disk File-
The backing disk partition number where the corresponding VM disk file resides. This optional parameter selects the information about the system disks that reside on the specified partition number on any disk.
[-vmdisk-backing-device-capacity {<integer>[KB|MB|GB|TB|PB]}]- Size of the Backing Device (Disk or LUN)-
The size of the backing device (disk or LUN) in bytes. This optional parameter selects the information about the system disks that have backing devices with the specified capacity.
The following example shows typical output from the system node virtual-machine instance show-system-disks command for the Data ONTAP node running on a virtual machine.
cluster1::> system node virtual-machine instance show-system-disks
Disk Disk Disk Store
Node Type Name Capacity Name VM Disk File Name
node1
Boot ad0 1.032 GB store1 store1/node1/DataONTAP.vmdk
Core ad1 1.505 GB store2 store2/node1/DataONTAP-var.vmdk
Log ad2 5.001 GB store3 store3/node1/DataONTAP-nvram.vmdk
Warning: Unable to list entries on node node2. Failed to connnect
to the vSphere server. Reason: Either the server hostname
or IP address is not set or there are network issues.
Correct the vSphere credentials using the "system node
virtual-machine hypervisor modify-credentials" command.
3 entries were displayed.
