vserver check lif-multitenancy show
Show the summary of the latest multitenancy network run
You can view summary information about the latest completed run, or the run in progress for a Vserver. It will show the following fields:
Vserver - Name of Vserver that was checked for LIF connectivity
Start Time - Date And Time the run was started
Status - Not Started, In Progress, Complete, or Aborted
Success - Yes if the run has a Status of Complete with no failures. No if the run has a status of Complete with one or more failures.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
Selects the summary information matching the specified Vserver.
[-start-time <MM/DD/YYYY HH:MM:SS>]
- Start Time-
Selects the summary information matching the specified date and time the run was started
[-status {not started|in progress|complete|aborted}]
- Run Status-
Selects the summary information matching the specified status of the run.
[-success {yes|no}]
- Successful Run-
Selects the summary information matching the specified success or failure of the run.
[-updated <MM/DD/YYYY HH:MM:SS>]
- Run Updated-
Selects the summary information matching the last time the run was still in progress.
This is what a successful run looks like:
cluster1::> vserver check lif-multitenancy show Vserver Start Time Status Success -------------- ------------------- ------------ ------- vs0 7/16/2014 14:28:35 complete yes
This is what a failed run looks like:
cluster1::> vserver check lif-multitenancy show Vserver Start Time Status Success -------------- ------------------- ------------ ------- vs0 7/16/2014 14:40:55 complete no
This is what specifying the Vserver looks like:
cluster1::> vserver check lif-multitenancy show -vserver vs0 Vserver: vs0 Start Time: 7/16/2014 14:40:55 Run Status: complete Successful Run: no
