ONTAP commands
vserver check lif-multitenancy show
(DEPRECATED)-Show the summary of the latest multitenancy network run
Note This command is deprecated and may be removed in a future release of ONTAP.
You can view summary information about the latest completed run, or the run in progress for a Vserver. It will show the following fields:
  • Vserver - Name of Vserver that was checked for LIF connectivity
  • Start Time - Date And Time the run was started
  • Status - Not Started, In Progress, Complete, or Aborted
  • Success - Yes if the run has a Status of Complete with no failures. No if the run has a status of Complete with one or more failures.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
Selects the summary information matching the specified Vserver.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
Selects the summary information matching the specified date and time the run was started
[-status {not started|in progress|complete|aborted}] - Run Status
Selects the summary information matching the specified status of the run.
[-success {yes|no}] - Successful Run
Selects the summary information matching the specified success or failure of the run.
[-updated <MM/DD/YYYY HH:MM:SS>] - Run Updated
Selects the summary information matching the last time the run was still in progress.
This is what a successful run looks like:
cluster1::> vserver check  lif-multitenancy show
     Vserver         Start Time           Status        Success
     vs0
                     7/16/2014 14:28:35   complete      yes
This is what a failed run looks like:
     vs0
                     7/16/2014 14:40:55   complete      no
This is what specifying the Vserver looks like:
cluster1::> vserver check lif-multitenancy show -vserver vs0
Vserver: vs0
        Start Time: 7/16/2014 14:40:55
        Run Status: complete
     Successful Run: no
