network port ifgrp add-port
Add a port to an interface group
The network port ifgrp add-port command adds a network port to a port interface group. The port interface group must already exist. You can create a port interface group by using the network port ifgrp create command.
The following restrictions apply to port interface groups:
A port that is already a member of a port interface group cannot be added to another port interface group.
Cluster ports and management ports cannot be in a port interface group.
A port to which a logical interface is already bound cannot be added to a port interface group.
A port that already has an assigned failover role cannot be added to a port interface group.
A VLAN port cannot be added to a port interface group.
A port which attaches to a VLAN cannot be added to a port interface group.
An interface group port cannot be added to a port interface group.
A port that is assigned to a broadcast domain cannot be added to a port interface group.
All ports in a port interface group must be physically located on the same node.
-node {<nodename>|local}- Node-
The node on which the port interface group is located.
-ifgrp <ifgrp name>- Interface Group Name-
The port interface group to which a port is to be added.
-port <netport>- Specifies the name of port.-
The network port that is to be added to the port interface group.
The following example adds port e0c to port interface group a1a on a node named node1:
cluster1::> network port ifgrp add-port -node node1 -ifgrp a1a -port e0c
