ONTAP commands
network ndp neighbor active-entry show
Display active neighbor entries organized by Vserver
The network ndp neighbor active-entry show command displays Network Discovery Protocol (NDP) neighbor cache entries on one or more nodes. You can view ndp neighbors within specified nodes and within specified System or Admin Vservers.
{ [-fields <fieldname>,…​]
| [-verbose ] (privilege: advanced)
Displays the expire time, state, is-router, and probe count fields.
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
Displays the NDP neighbors from the specified node.
[-vserver <vserver>] - System or Admin Vserver Name (privilege: advanced)
Displays the NDP neighbors from the specified System or Admin Vserver. Data and Node Vservers do not have dynamic NDP neighbors.
[-subnet-group <IP Address/Mask>] - Subnet Group (privilege: advanced)
Displays the NDP neighbors in the specified subnet group.
[-neighbor <IP Address>] - Neighbor (privilege: advanced)
Displays the NDP neighbors that have the specified IPv6 address.
[-port {<netport>|<ifgrp>}] - Port (privilege: advanced)
Displays the NDP neighbors on the specified port.
[-mac-address <MAC Address>] - MAC Address (privilege: advanced)
Displays the NDP neighbors have the specified MAC address.
[-expire-time {[<integer>d][<integer>h][<integer>m][<integer>s]|never|expired}] - Expire Time (privilege: advanced)
Displays the NDP neighbors have the specified expire time.
[-state {<nostate|incomplete|reachable|stale|delay|probe|unknown>}] - State (privilege: advanced)
Displays the NDP neighbors in the specified state.
[-is-router {true|false}] - Is Router (privilege: advanced)
Displays the NDP neighbor which is a router.
[-probe-count <integer>] - Probe Count (privilege: advanced)
Displays the NDP neighbors with the specified probe count. Probe count is the number of times that this neighbor's MAC address has been queried.
[-is-static {true|false}] - Is Static (privilege: advanced)
Displays the NDP neighbors which are statically configured.
The following example displays NDP neighbors on the Admin Vserver cluster1:
cluster1::*> network ndp neighbor active-entry show -vserver cluster1
Node: node1
Vserver: cluster1
Subnet Group: ::/0
Neighbor                       MAC Address          Port
fe80:4::5:73ff:fea0:107        00:05:73:a0:01:07    e0d
fe80:4::226:98ff:fe0c:b6c1     00:26:98:0c:b6:c1    e0d
fe80:4::4255:39ff:fe25:27c1    40:55:39:25:27:c1    e0d
3 entries were displayed.
