network interface service-policy show
Display existing service policies
The network interface service-policy show command displays existing service policies.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects service policies that match the specified vserver name.
[-policy <text>]- Policy Name-
Selects service policies that match the specified service policy name.
[-services <LIF Service Name>,…]- Included Services-
Selects service policies that contain all services in the specified list of service names.
[-service-allowed-addresses <text>,…]- Service: Allowed Addresses-
"<service>:<allowed-addresses>"in the specified list of addresses.
The following example displays the built-in service policies.
cluster1::> network interface service-policy show
Vserver Policy Service: Allowed Addresses
cluster1
net-route-announce management-bgp: 0.0.0.0/0
net-intercluster intercluster-core: 0.0.0.0/0
2 entries were displayed.
