system cluster-switch log show
Displays cluster switch log information
The system cluster-switch log show command displays the status and requests for cluster switch logs.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
Specifies an instance of the cluster switch devices log status.
- [-device <text>]- Switch Name
Specifies the name of the cluster switch device to display log status on.
- [-log-request {true|false}]- Requested Log
Specifies the state of the log request for a cluster switch device. Values: true, false.
- [-log-status <text>]- Log Status
Specifies the status of the log request for a cluster switch device.
- [-log-timestamp <MM/DD/YYYY HH:MM:SS>]- Log Timestamp
Specifies the completion timestamp of the log request for a cluster switch device.
- [-idx <integer>]- Index
Specifies the index of the cluster switch device.
- [-filename <text>]- Filename
Specifies the full filename of the cluster switch log.
- [-filenode <text>]- File Node
Specifies the name of the controller on which the cluster switch log resides.
cluster1::> system cluster-switch log show
Log Collection Enabled: true
Index Switch                               Log Timestamp        Status
         1 switch-name01(Switch---SN)           -                    -
         2 switch-name02(Switch---SN)           -                    -
Displays the cluster switches, their last log timestamp, and the status of the last log request.
 PDFs
PDFs
