system cluster-switch log show
Displays cluster switch log information
The system cluster-switch log show command displays the status and requests for cluster switch logs.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Specifies an instance of the cluster switch devices log status.
[-device <text>]- Switch Name-
Specifies the name of the cluster switch device to display log status on.
[-log-request {true|false}]- Requested Log-
Specifies the state of the log request for a cluster switch device. Values: true, false.
[-log-status <text>]- Log Status-
Specifies the status of the log request for a cluster switch device.
[-log-timestamp <MM/DD/YYYY HH:MM:SS>]- Log Timestamp-
Specifies the completion timestamp of the log request for a cluster switch device.
[-idx <integer>]- Index-
Specifies the index of the cluster switch device.
[-filename <text>]- Filename-
Specifies the full filename of the cluster switch log.
[-filenode <text>]- File Node-
Specifies the name of the controller on which the cluster switch log resides.
cluster1::> system cluster-switch log show
Log Collection Enabled: true
Index Switch Log Timestamp Status
1 switch-name01(Switch---SN) - -
2 switch-name02(Switch---SN) - -
Displays the cluster switches, their last log timestamp, and the status of the last log request.
