event status show
PDF of this doc site
Creating your file...
Your file is ready
Display event status
The event status show
command summarizes information about occurrences of events. For detailed information about specific occurrences of events, use the event log show command.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the event records that match this parameter value. Events are tracked on a node-by-node basis, rather than being rolled up cluster-wide.
[-message-name <Message Name>]
- Message Name-
