ONTAP commands
network options port-health-monitor show
Display port health monitors configuration
This command displays the enabled port health monitors for the IPspaces in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-ipspace <IPspace>] - IPspace Name (privilege: advanced)
Displays the port health monitors that are enabled only for the given IPspace name.
[-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}] - List of Enabled Port Health Monitors (privilege: advanced)
Displays the IPspaces that have the given monitors enabled.
The following example lists all port health monitors that are enabled for all IPspaces in the cluster.
cluster1::*> network options port-health-monitor show
IPspace         Enabled Port Health Monitors
Cluster         l2_reachability,
                link_flapping
Default         l2_reachability,
                link_flapping
2 entries were displayed.
Looking for answers?
Try Doc, our Gen AI Assistant.
