system license clean-up
Remove unnecessary licenses
This command manages licenses in the cluster that have no effect, and so can be removed. Licenses that have expired or are not affiliated with any controller in the cluster are deleted by this command.
[-unused <true>]
- Remove unused licenses-
If you use this parameter, the command removes licenses in the cluster that are not affiliated with any controller in the cluster.
[-expired <true>]
- Remove expired licenses-
If you use this parameter, the command removes licenses in the cluster that have expired.
[-n, -simulate <true>]
- Simulate Only-
If you use this parameter, the command will not remove the licenses. Instead it will display the licenses that will be removed if this parameter was not provided.
The following example simulates and displays the licenses that can be cleaned up:
cluster1::> system license clean-up -n -unused -expired Serial number: 1-80-000011 Owner: cluster1 Package Reason ------------------------- ----------------------------------------------------- SnapLock Demo License has expired SnapProtectApps Demo License has expired Serial number: 1-81-0000000000000004062522917 Owner: none Package Reason ------------------------- ----------------------------------------------------- NFS Serial number is not used by any node in the cluster CIFS Serial number is not used by any node in the cluster
The following example deletes the expired licenses:
cluster1::> system license clean-up -expired 2 demo licenses deleted.
The following example deletes the unused licenses:
cluster1::> system license clean-up -unused 2 unused licenses deleted.
