vserver audit show
Display the audit configuration
The vserver audit show command displays audit configuration information about Vservers. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all the Vservers:
Vserver name
Audit state
Target directory
You can specify the -fields parameter to specify which audit configuration information to display about Vservers. + You can specify additional parameters to display only information that matches those parameters. For instance, to display information about the log file rotation size of a Vserver whose value matches 10 MB, run the command with the -rotate-size 10MB parameter.
You can specify the -instance parameter to display audit configuration information for all Vservers in list form.
[-fields <fieldname>,…] -
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-log-save-details ] -
You can specify the
-log-save-detailsparameter to display the following information about all the Vservers:-
Vserver name
Rotation file size
Rotation schedules
Rotation limit
[-instance ]} -
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information about the specified Vserver.
[-state {true|false}]- Auditing State-
If you specify this parameter, the command displays information about the Vservers that use the specified audit state value.
[-destination <text>]- Log Destination Path-
If you specify this parameter, the command displays information about the Vservers that use the specified destination path.
[-events {file-ops|cifs-logon-logoff|cap-staging|file-share|audit-policy-change|user-account|authorization-policy-change|security-group}]- Categories of Events to Audit-
If you specify this parameter, the command displays information about the Vservers that use the specified category of events that are audited. Valid values are
file-ops,cifs-logon-logoff,cap-staging,file-share,audit-policy-change,user-account,security-groupandauthorization-policy-change.audit-policy-changewill appear only in diag mode. [-format {xml|evtx}]- Log Format-
If you specify this parameter, the command displays information about the Vservers that use the specified log format.
[-rotate-size {<integer>[KB|MB|GB|TB|PB]}]- Log File Size Limit-
If you specify this parameter, the command displays information about the Vservers that use the specified log file rotation size.
[-rotate-schedule-month <cron_month>,…]- Log Rotation Schedule: Month-
If you specify this parameter, the command displays information about the Vservers that use the specified month of the time-based log rotation scheme. Valid values are January, February, March, April, May, June, July, August, September, October, November, and December.
[-rotate-schedule-dayofweek <cron_dayofweek>,…]- Log Rotation Schedule: Day of Week-
If you specify this parameter, the command displays information about the Vservers that use the specified day of the week of the time-based log rotation scheme. Valid values are Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
[-rotate-schedule-day <cron_dayofmonth>,…]- Log Rotation Schedule: Day-
If you specify this parameter, the command displays information about the Vservers that use the specified day of the month of the time-based log rotation scheme. Valid values range from 1 to 31.
[-rotate-schedule-hour <cron_hour>,…]- Log Rotation Schedule: Hour-
If you specify this parameter, the command displays information about the Vservers that use the specified hour of the time-based log rotation scheme. Valid values range from 0 (midnight) to 23 (11:00 p.m.).
[-rotate-schedule-minute <cron_minute>,…]- Log Rotation Schedule: Minute-
If you specify this parameter, the command displays information about the Vservers that use the specified minute of the time-based log rotation scheme. Valid values range from 0 to 59.
[-rotate-schedule-description <text>]- Rotation Schedules-
If you specify this parameter, the command displays information about the Vservers that use the specified rotation schedules. This field is derived from the rotate-time fields.
[-rotate-limit <integer>]- Log Files Rotation Limit-
If you specify this parameter, the command displays information about the Vservers that use the specified rotation limit value.
[-retention-duration <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Log Retention Duration-
If you specify this parameter, the command displays information about the Vservers audit logs retention duration.
The following example displays the name, audit state, event types, log format, and target directory for all Vservers.
cluster1::> vserver audit show Vserver State Event Types Log Format Target Directory ----------- ------ ----------- ---------- -------------------- vs1 false file-ops evtx /audit_log
The following example displays the Vserver names and details about the audit log for all Vservers.
cluster1::> vserver audit show -log-save-details Rotation Rotation Vserver File Size Rotation Schedule Limit ----------- --------- ------------------------ -------- vs1 100MB - 0
The following example displays in list form all audit configuration information about all Vservers.
cluster1::> vserver audit show -instance
Vserver: vs1
Auditing state: true
Log Destination Path: /audit_log
Categories of Events to Audit: file-ops
Log Format: evtx
Log File Size Limit: 100MB
Log Rotation Schedule: Month: -
Log Rotation Schedule: Day of Week: -
Log Rotation Schedule: Day: -
Log Rotation Schedule: Hour: -
Log Rotation Schedule: Minute: -
Rotation Schedules: -
Log Files Rotation Limit: 0
Log Retention Time: 0s
