vserver nvme subsystem show
Display NVMe target subsystems
The vserver nvme subsystem show command displays information for NVMe subsystems.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the NVMe subsystems that match the Vserver that you specify.
 [-subsystem <text>]- Subsystem-
Use this parameter to display the NVMe subsystem that matches the name that you specify.
 [-ostype {windows|linux|vmware|xen|hyper_v}]- OS Type-
Use this parameter to display the NVMe subsystems that match this parameter value.
 [-comment <text>]- Comment-
 [-target-nqn <text>]- Target NQN-
 [-serial-number <text>]- Serial Number-
 [-default-io-queue-count <integer>]- Default Number of Host I/O Queue Pairs-
Specifies the default maximum IO queue count inherited by hosts added to this subsystem.
 [-default-io-queue-depth <integer>]- Default Host I/O Queue Depth-
Specifies the default maximum IO queue depth inherited by hosts added to this subsystem.
cluster1::*> vserver nvme subsystem show -vserver vs_1
Vserver Subsystem    Target NQN
vs_1
        ss1          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss1
        ss2          nqn.1992-08.netapp.com:sn.ccb5a7d5d9d311e7924e005056b45113:subsystem.ss2
2 entries were displayed.
