security certificate delete
Delete an Installed Digital Certificate
This command deletes an installed digital security certificate.
-vserver <Vserver Name>- Name of Vserver-
This specifies the Vserver that contains the certificate.
-common-name <FQDN or Custom Common Name>- FQDN or Custom Common Name-
This specifies the desired certificate name as a fully qualified domain name (FQDN) or custom common name or the name of a person. The supported characters, which are a subset of the ASCII character set, are as follows:
Letters a through z, A through Z
Numbers 0 through 9
Asterisk (*), period (.), underscore (_) and hyphen (-)
The common name must not start or end with a "-" or a ".". The maximum length is 253 characters.
[-serial <text>]- Serial Number of Certificate-
This specifies the certificate serial number.
-ca <text>- Certificate Authority-
This specifies the certificate authority (CA).
-type <type of certificate>- Type of Certificate-
This specifies the certificate type. Valid values are the following:
server- includes server certificates and intermediate certificates -
root-ca- includes a self-signed digital certificate to sign other certificates by acting as a certificate authority (CA) -
client-ca- includes the public key certificate for the root CA of the SSL client. If this client-ca certificate is created as part of a root-ca, it will be deleted along with the corresponding deletion of the root-ca. -
server-ca- includes the public key certificate for the root CA of the SSL server to which Data ONTAP is a client. If this server-ca certificate is created as part of a root-ca, it will be deleted along with the corresponding deletion of the root-ca. -
client- includes a public key certificate and private key to be used for Data ONTAP as an SSL client
[-subtype <kmip-cert>]- Certificate Subtype-
This specifies a certificate subtype. This optional parameter can have an empty value (the default). The only valid value is as follows:
kmip-cert- this is a Key Management Interoperability Protocol (KMIP) certificate
This example deletes a root-ca type digital certificate for a Vserver named vs0 in a company named www.example.com with serial number 4F57D3D1.
cluster1::> security certificate delete -vserver vs0 -common-name `_www.example.com_` -ca `_www.example.com_` -type root-ca -serial 4F57D3D1
