vserver cifs users-and-groups local-group show
Display local groups
The vserver cifs users-and-groups local-group show command displays local groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays information only about local groups that match the specified Vserver name.
[-group-name <CIFS name>]- Group Name-
If this parameter is specified, the command displays information only about local groups that match the specified group name.
[-description <TextNoCase>]- Description-
If this parameter is specified, the command displays information only about local groups that match the specified description.
The following example displays all local groups associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group show -vserver vs1 Vserver Group Name Description -------------- -------------------------------- ---------------------------- vs1 BUILTIN\Administrators Built-in Administrators group vs1 BUILTIN\Backup Operators Backup Operators group vs1 BUILTIN\Power Users Restricted administrative privileges vs1 BUILTIN\Users All users vs1 CIFS_SERVER\g1 vs1 CIFS_SERVER\g2 6 entries were displayed.
