ONTAP 9.5 commands
storage aggregate show-resync-status
Display aggregate resynchronization status
The storage aggregate show-resync-status command displays resync status information for each plex. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all aggregates:
  • Aggregate Name
  • Resyncing Plex Name
  • Resyncing Percentage
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
This parameter specifies the name of the aggregate.
[-plex <text>] - Plex Name
This parameter specifies the name of the plex.
[-status <text>] - Status
Displays plex status. Possible values are:
  • normal
  • failed
  • empty
  • invalid
  • uninitialized
  • failed assimilation
  • limbo
  • active
  • inactive
  • resyncing
These values may appear by themselves or in combination separated by commas; for example, "normal ,active ".
[-is-online {true|false}] - Is Online
Indicates whether the plex is online.
[-in-progress {true|false}] - Resync is in Progress
Indicates whether the plex is currently resyncing.
[-resyncing-percent <percent>] - Resyncing Percentage
Displays the resynchronization completion percentage if the plex is currently being resynced, '-' otherwise.
[-resync-level <integer>] - Resync Level
Displays the resync level if the plex is currently being resynced, '-' otherwise.
[-pool <integer>] - Pool
The pool number to which the majority of disks in the plex belong.
The following example displays resynchronization status for all the aggregates:
cluster1::> storage aggregate show-resync-status
                                    Complete
Aggregate Resyncing Plex            Percentage
aggr0     plex0                              -
aggr1     plex0                              -
aggr1     plex1                          10.00
aggr2     plex0                              -
aggr2     plex2                              -
5 entries were displayed.
