      system services manager policy add
Add a new service policy
The system services manager policy add command adds a new service policy to the services manager. Policies determine which versions of a service can run on the nodes of the cluster.
-service <text>- Service-
Use this parameter to specify the name of the service for which to add a policy.
 -version <service version>- Version-
Use this parameter to specify the minimum version number of the service to run.
This example adds a service manager policy for version 1.0 of the diagnosis service.
cluster1::> system services manager policy add -service diagnosis -version 1.0
