system license license-manager check
Display license manager status
The ` system license license-manager check ` checks the connectivity status of a node to the License Manager that the node was configured to use.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
This parameter directs the system to display results for the License Manager configured for the specified node.
[-status <text>]- Status (privilege: advanced)-
This parameter directs the system to display results for the given status message.
The following example checks the status of the configured License Manager:
cluster1::*> system license license-manager check -node node1 Node: node1 LM status: License Manager (1.2.3.4:5678) is accessible. cluster1::*> system license license-manager check Node Status --------------- ------------------------------------------------------ node1 License Manager (1.2.3.4:5678) is accessible. node2 License Manager (1.2.3.4:5678) is accessible. 2 entries were displayed.
