system license license-manager check
Display license manager status
The ` system license license-manager check ` checks the connectivity status of a node to the License Manager that the node was configured to use. The status of a node might indicate that the License Manager is inaccessible. If so, the status message contains additional text in parentheses. The text options and descriptions are as follows:
license_expired : The License Manager has a license, but it is expired.
network_error : The node is unable to establish basic network connectivity.
no_valid_license : The License Manager does not have a valid capacity pool license.
All other values indicate an internal error.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
This parameter directs the system to display results for the License Manager configured for the specified node.
 [-status <text>]- Status (privilege: advanced)-
This parameter directs the system to display results for the given status message.
The following examples check the status of the configured License Manager, before and after its license has expired:
cluster1::*> system license license-manager check -node node1 Node: node1 LM status: License Manager (1.2.3.4:5678) is accessible. cluster1::*> system license license-manager check Node Status --------------- ------------------------------------------------------ node1 License Manager (1.2.3.4:5678) is accessible. node2 License Manager (1.2.3.4:5678) is accessible. 2 entries were displayed. cluster1::*> system license license-manager check -node node1 Node: node1 LM status: License Manager (1.2.3.4:5678) is inaccessible (license_expired). cluster1::*> system license license-manager check Node Status --------------- ------------------------------------------------------ node1 License Manager (1.2.3.4:5678) is inaccessible (license_expired). node2 License Manager (1.2.3.4:5678) is inaccessible (license_expired). 2 entries were displayed.
