ONTAP commands
storage bridge add
Add a bridge for monitoring
The storage bridge add command enables you to add FC-to-SAS bridges for SNMP monitoring in a MetroCluster configuration.
-address <IP Address> - Bridge Management Port IP Address
This parameter specifies the IP address of the bridge that is being added for monitoring.
[-managed-by {SNMP|in-band}] - Bridge Management Method
This parameter specifies whether the bridge uses the SNMP or in-band management method. FibreBridge 6500N uses SNMP only; FibreBridge7500 may use either.
[-name <text>] - Bridge Name
This parameter identifies the bridge being added. It is required only when the managed-by parameter is set to in-band.
[-snmp-community <text>] - SNMP Community
This parameter specifies the SNMP community set on the bridge that is being added for monitoring.
[-veto-backend-fabric-check {true|false}] - Veto Backend Fabric Check (privilege: advanced)
If specified, the storage bridge add command will not check if the bridge is present in the MetroCluster's backend fabric. By default, it does not let you add bridges that are not present.
The following command adds a bridge with IP address '10.226.197.16' for monitoring:
cluster1::> storage bridge add -address 10.226.197.16
cluster1::> storage bridge show
        Is        Managed Monitor
    Bridge     Symbolic Name Vendor  Model     Bridge WWN       Monitored By      Status
    ATTO_10.226.197.16
               Bridge Number 16
                             Atto    FibreBridge 6500N
                                               2000001086603824 true      SNMP    -
    ATTO_FibreBridge6500N_2
               Not Set       Atto    FibreBridge 6500N
                                               20000010866037e8 false     SNMP    -
    ATTO_FibreBridge6500N_3
                                               2000001086609e0e false     SNMP    -
    ATTO_FibreBridge6500N_4
                                               2000001086609c06 false     SNMP    -
    4 entries were displayed.
cluster1::>
