ONTAP commands
storage aggregate plex show
Show plex details
The storage aggregate plex show command displays information for the specified plex. By default, the command displays the following information about all plexes:
  • Aggregate Name
  • Plex Name
  • Is Online
  • Is Resyncing
  • Resyncing Percentage
  • Plex Status
To display detailed information about a single plex, use the -aggregate and -plex parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
Name of an existing aggregate which contains the plex specified with the -plex parameter.
[-plex <text>] - Plex Name
Name of a plex which belongs to the aggregate specified with the -aggregate parameter.
[-status <text>] - Status
Displays plex status. Possible values are:
  • normal
  • failed
  • empty
  • invalid
  • uninitialized
  • failed assimilation
  • limbo
  • active
  • inactive
  • resyncing
These values may appear by themselves or in combination separated by commas, for example, "normal ,active ".
[-is-online {true|false}] - Is Online
Selects the plexes that match this parameter value.
[-in-progress {true|false}] - Resync is in Progress
[-resyncing-percent <percent>] - Resyncing Percentage
[-resync-level <integer>] - Resync Level
[-pool <integer>] - Pool
The following example displays information about all the plexes for all the aggregates:
cluster1::> storage aggregate plex show
                    Is      Is         Resyncing
Aggregate Plex      Online  Resyncing    Percent Status
aggr0     plex0     true    false              - normal,active
aggr1     plex0     true    false              - normal,active
aggr1     plex1     true    false              - normal,active
aggr2     plex0     true    false              - normal,active
aggr2     plex2     true    false              - normal,active
5 entries were displayed.
The following example displays information about plex1 of aggregate aggr1:
cluster1::> storage aggregate plex show -aggregate aggr1 -plex plex1
Aggregate: aggr1
            Plex Name: plex1
               Status: normal,active
            Is Online: true
Resync is in Progress: false
 Resyncing Percentage: -
         Resync Level: -
                 Pool: 1
