      vserver iscsi session shutdown
Shut down a session on a node
This command forces a shutdown of all connections in a session. If you want to shut down a single connection in a session, use the vserver iscsi connection shutdown command.
- -vserver <Vserver Name>- Vserver (privilege: advanced)
Specifies the Vserver.
- -tpgroup <text>- Target Portal Group (privilege: advanced)
Specifies the target portal group that contains the session you want to shutdown.
- -tsih <integer>- Target Session ID (privilege: advanced)
Specifies the target session ID that you want to shut down.
cluster1::*> vserver iscsi session shutdown -vserver vs_1 -tpgroup tpgroup_1 -tsih 2
Forces a session shutdown for target session ID 2 in tpgroup_1 in Vserver vs_1 .
 PDFs
PDFs
