ONTAP commands
vserver services ndmp extensions show
Display NDMP extension status
This command displays whether an NDMP extension is enabled in the Vserver-aware NDMP mode or not.
The following example shows how to check the status of NDMP extension 0x2050 in a cluster :
cluster1::> vserver services ndmp extension show
Is Extension 0x2050 Enabled: true
cluster1::>
Looking for answers?
Try Doc, our Gen AI Assistant.
