The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver services ndmp extensions show
PDF of this doc site
Creating your file...
Your file is ready
Display NDMP extension status
This command displays whether an NDMP extension is enabled in the Vserver-aware NDMP mode or not.
The following example shows how to check the status of NDMP extension 0x2050 in a cluster :
cluster1::> vserver services ndmp extension show Is Extension 0x2050 Enabled: true cluster1::>
