event filter copy
Copy an event filter
The event filter copy command copies an existing filter to a new filter. The new filter will be created with rules from the source filter. For more information, see the event filter create command.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter to copy.
-new-filter-name <text> - New Event Filter Name
Use this mandatory parameter to specify the name of the new event filter to create and copy the rules.
The following example copies an existing event filter named emer-wafl-events to a new filter named filter1:
cluster1::> event filter show
Filter Name Rule     Rule      Message Name
