ONTAP commands
storage aggregate show-scrub-status
Display aggregate scrubbing status
The storage aggregate show-scrub-status command displays the following information about the scrub status of aggregates:
  • Aggregate name
  • RAID groups
  • Whether the scrub is suspended
  • Percentage of the scrub that is completed
  • Last scrub time of the aggregate
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
If this parameter is specified, the command displays detailed scrub-status information about the specified aggregate.
[-raidgroup <text>] - RAID Group
If this parameter is specified, the command displays information only about the aggregate that contains the specified RAID group.
[-node {<nodename>|local}] - Node
If this parameter is specified, the command displays information only about the aggregates on the specified node. The value local specifies the current node.
[-suspended {true|false}] - Is Suspended
If this parameter is specified, the command displays information only about the aggregates that have the specified scrub-suspension state (true or false).
[-complete-percentage <percent>] - Percentage Completed
If this parameter is specified, the command displays information only about the aggregates whose scrubs have the specified completed percentage.
[-last-scrub-time <MM/DD/YYYY HH:MM:SS>] - Last Scrub Time
If this parameter is specified, the command displays information only about the aggregates that have the specified last-scrub time, in the format MM/DD/YYYY HH:MM:SS .
The following example displays scrub-status information for all the aggregates:
cluster1::> storage aggregate show-scrub-status
Aggregate RAID Groups         Suspended  Percentage Last Scrub Time
aggr0     /aggr0/plex0/rg0    true               0% 3/31/2011  21:23:02
aggr1     /aggr1/plex0/rg1    true              45% 3/30/2011  01:05:00
aggr2     /aggr2/plex0/rg0    true              33% 3/30/2011  23:43:34
aggr3     /aggr3/plex0/rg1    true              79% 3/29/2011  00:34:36
4 entries were displayed.
The following example displays detailed information about the aggregate named aggr1:
cluster1::> storage aggregate show-scrub-status -instance -aggregate aggr1
           Aggregate: aggr1
          RAID Group: /aggr1/plex0/rg0
        Is Suspended: false
Percentage Completed: 2%
     Last Scrub Time: 3/31/2011 22:02:50
