application show-detail
(DEPRECATED)-Display application details
This command is deprecated and may be removed in a future release of Data ONTAP. Use the REST interface instead. |
This command displays storage and protocol elements of applications.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected application.
[-vserver <vserver name>]- Vserver-
Selects elements of applications belonging to Vservers that match the parameter value.
[-application <text>]- Application-
Selects elements of applications with an application name that matches the parameter value.
[-element-type {lun|lun-clone|nas|igroup}]- Type of Object-
Selects application elements with type that matches the parameter value. Possible values are
lunfor application provisioned LUNs on SAN applications,lun-clonefor auxiliary LUNs in SAN applications,igroupfor protocol elements in SAN applications andnasfor application provisioned storage and protocol information in NAS applications. [-application-component <text>]- Application Component-
Selects application elements which belong to the application component that matches the parameter value. Only application provisioned storage elements of type
lun,nascan belong to application components. [-element-name <text>]- Name of Object-
Selects application elements with an element name that matches the parameter value.
[-application-template <text>]- Application Template-
Selects application elements that belong to applications with templates that match the parameter value.
[-application-template-version <integer>]- Application Template Version-
Selects application elements that belong to applications with template version that match the parameter value.
[-application-uuid <UUID>]- Application UUID-
Selects application elements that belong to applications whose UUID matches the parameter value.
[-application-component-uuid <UUID>]- Application Component UUID-
Selects application elements which belong to the application component whose UUID that matches the parameter value.
[-application-component-storage-service <text>]- Storage Service-
Selects application elements which belong to the application component with a storage service that matches the parameter value.
[-application-protection-granularity {application|component}]- Application Protection Granularity-
Selects application elements which belong to applications whose protection granularity matches the parameter value. Protection granularity determines the scope of Snapshot operations for the application. Possible values are
applicationandcomponent. If the value isapplication, Snapshot operations are performed on the entire application. If the value iscomponent, Snapshot operations are performed separately on the application components. [-nas-element-path <junction path>]- Volume Path-
Selects application elements with a NAS element path that matches the parameter value. This field is valid only for elements of type
nas. [-nas-element-size {<integer>[KB|MB|GB|TB|PB]}]- Volume Size-
Selects application elements with NAS element size that matches the parameter value. This field is valid only for elements of type
nas [-cifs-share-name <Share>]- CIFS Share Name-
Selects application elements with a CIFS share that matches the parameter value. This field is valid only for elements of type
nas. [-cifs-server-fqdn <text>]- CIFS Server Name-
Selects application elements with a CIFS Server that matches the parameter value. This field is valid for only elements of type
nas. [-cifs-permissions <text>,…]- CIFS User Permissions-
Selects application elements with CIFS Permissions that matches the parameter value. This field is valid for only elements of type
nas. [-cifs-access-ips <IP Address>,…]- Recommended LIFs for CIFS-
Selects application elements with CIFS LIFs that matches the parameter value. This field is valid for only elements of type
nas. The CIFS access IPs are recommended LIFs for CIFS access. If LIFs local to the volume are available, then these are recommended. If not, two remote LIFs are returned. Data can be accessed over other available LIFs but that is not recommended. [-nfs-export-policy-name <export policy name>]- Export Policy Name-
Selects application elements with an export policy name that matches the parameter value. This field is valid for only elements of type
nas. [-nfs-permissions <text>,…]- NFS Permissions-
Selects application elements with NFS permissions that matches the parameter value. This field is valid for only elements of type
nas. [-nfs-access-ips <IP Address>,…]- Recommended LIFs for NFS-
Selects application elements with NFS LIFs that matches the parameter value. This field is valid for only elements of type
nas. The NFS access IPs are recommended LIFs for NFS access. If LIFs local to the volume are available, then these are recommended. If not, two remote LIFs are returned. Data can be accessed over other available LIFs but that is not recommended. [-lun <text>]- LUN Name-
Selects application elements with a LUN name that matches the parameter value. This field is valid for only elements of type
lunandlun-clone. [-lun-path <path>]- LUN Path-
Selects application elements with LUN path that matches the parameter value. This field is valid for only elements of type
lunandlun-clone. [-serial <text>]- LUN Serial-
Selects application elements with a LUN serial number that matches the parameter value. This field is valid for only elements of type
lunandlun-clone. [-lun-ids <integer>,…]- LUN IDs-
Selects application elements with LUN IDs that match the parameter value. This field is valid for only elements of type
lunandlun-clone. [-size {<integer>[KB|MB|GB|TB|PB]}]- Element Size-
Selects application elements with a LUN size that matches the parameter value. This field is valid for only elements of type
lunandlun-clone. [-igroups <text>,…]- Igroups-
Selects application elements mapped to igroups with names that match the parameter value. This field is valid for only elements of type
lunandlun-clone. [-initiator <text>,…]- Initiators-
Selects application elements mapped to initiators that matches the parameter value. This field is valid for only elements of type
igroup. [-is-protection-supported {true|false}]- Is Protection Supported-
Selects applications with is-protection-supported flag that matches the parameter value. The is-protection-supported flag indicates if any type of protection is supported for the application.
[-is-protected {true|false}]- Is Application Protected-
Selects applications with is-protected flag that matches the parameter value. The is-protected flag indicates if any type of protection is enabled for the application.
[-local-RPO <text>]- Local RPO-
Selects applications with local-RPO that matches the parameter value.
[-local-RPO-description <text>]- Local RPO description-
Selects applications with local-RPO-descriptions that match the parameter value. The local RPO description provides details about the local RPO associated with the application.
[-remote-RPO <text>]- Remote RPO-
Selects applications with remote-RPO that matches the parameter value.
[-remote-RPO-description <text>]- Remote RPO description-
Selects applications with remote-RPO-descriptions that match the parameter value. The remote RPO description provides details about the remote RPO associated with the application.
cluster1::> application show-detail -vserver vs0
rupancluster-1::*> application show-detail =============================================================================
Vserver: vs0
Application: my_nas_app
Application Template: NAS
NAS Storage Element
Component: data
Storage Service: value
Element: my_nas_app_data_1
Path: /my_nas_app_data_1
CIFS Share: my_nas_app_data_1
CIFS Server: KTCIFS.
CIFS User Permissions: Everyone / Read
CIFS LIFs: 10.10.10.20
Export Policy: my_nas_app
NFS Permissions: 0.0.0.0/0 / ro
NFS LIFs: 10.10.10.20
Vserver: vs0
Application: my_san_app
Application Template: SAN
SAN Storage Element
Component: data_group1
Element: data_group1_1
Path: /vol/my_san_app_data_group1_1/data_group1_1
Serial Number: w89ST?JTeR7V
Igroups: igroup1
LUN IDs: 0
SAN Storage Element
Element: data_group1_2
Path: /vol/my_san_app_data_group1_1/data_group1_2
Serial Number: w89ST?JTeR7W
Igroups: igroup1
LUN IDs: 1
SAN Storage Element
Element: data_group1_3
Path: /vol/my_san_app_data_group1_1/data_group1_3
Serial Number: w89ST?JTeR7X
Igroups: igroup1
LUN IDs: 2
SAN Storage Element
Element: data_group1_4
Path: /vol/my_san_app_data_group1_1/data_group1_4
Serial Number: w89ST?JTeR7Y
Igroups: igroup1
LUN IDs: 3
SAN Storage Element
Component: redolog_group1
Element: redolog_group1_1
Path: /vol/my_san_app_redolog_group1_1/redolog_group1_1
Serial Number: w89ST?JTeR7Z
Igroups: igroup2
LUN IDs: 0
SAN Storage Element
Element: redolog_group1_2
Path: /vol/my_san_app_redolog_group1_1/redolog_group1_2
Serial Number: w89ST?JTeR7/
Igroups: igroup2
LUN IDs: 1
Auxiliary LUN
Element: redolog_group1_2_clone
Path: /vol/my_san_app_redolog_group1_1/redolog_group1_2_clone
Serial Number: w89ST?JTeR7a
SAN Protocol Info
Igroup: igroup1
Initiators: iqn.1995-08.com.example3, iqn.1995-08.com.example4
SAN Protocol Info
Igroup: igroup2
Initiators: iqn.1995-08.com.example1, iqn.1995-08.com.example2
10 entries were displayed.
The above example displays the details of all applications in Vserver vs0.
cluster1: : > application show-detail -vserver vs0 -application my_san_app
Vserver: vs0
SAN Storage Element
Igroups: igroup1, igroup2
LUN IDs: 0, 0
SAN Storage Element
LUN IDs: 1, 1
SAN Storage Element
LUN IDs: 2, 2
SAN Storage Element
LUN IDs: 3, 3
SAN Storage Element
Igroups: igroup2
LUN IDs: 0
SAN Storage Element
Igroups: igroup2
LUN IDs: 1
Auxiliary LUN
SAN Protocol Info
Igroup: igroup1
SAN Protocol Info
Igroup: igroup2
9 entries were displayed.
The above example displays the details of application my_san_app in Vserver vs0.
cluster1: : > application show-detail -vserver vs0 -application my_san_app -application-component data_group1
Vserver: vs0
SAN Storage Element
Igroups: igroup1
LUN IDs: 0
SAN Storage Element
Igroups: igroup1
LUN IDs: 1
SAN Storage Element
Igroups: igroup1
LUN IDs: 2
SAN Storage Element
Igroups: igroup1
LUN IDs: 3
4 entries were displayed.
The above example displays the details elements belonging to application-component data_group1 in application my_san_app in Vserver vs0.
