system node virtual-machine show-network-load-balancer
Display network load balancer information
The system node virtual-machine show-network-load-balancer displays the list of network load balancer probe ports for each ONTAP node in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-vserver-name <text>] - Vserver Name
Vserver name.
[-lif-name <text>] - ONTAP LIF Name
ONTAP logical interface name.
[-probe-port <integer>] - Probe Port
A TCP port which is regularly probed by the network load balancer. When the TCP port is healthy and open, the network load balancer will continue sending traffic to an associated network route. When unhealthy, the network load balancer will redirect all traffic intended for this route to an alternate route.
[-last-probe-time <MM/DD/YYYY HH:MM:SS>] - Last Probe Time
The timestamp of the most recent health probe request on this TCP port.
[-remove-listener {true|false}] - Remove listener for This LIF
Whether or not ONTAP has programmatically told the network load balancer to stop listening on the health probe associated with this LIF.
[-active {true|false}] - Actively receiving Health Probes
Whether or not the network load balanacer has received a health probe request on this TCP port, within the expecteced timeframe.
The following example displays probe ports for each node in the cluster.
cluster1::*> system node virtual-machine show-network-load-balancer
                                   Logical           Probe
Node             Vserver           Interface         Port       Last Probe Time
node1            vserver0          data_lif1         63002    5/8/2018 19:22:47
                 cluster1          cluster_mgmt      63001    5/8/2018 19:22:43
node2            vserver0          data_lif2         63003    5/8/2018 19:22:44
                 vserver0          svm_mgmt          63004    5/8/2018 19:22:50
4 entries were displayed.
